本帖最后由 tkl045 于 15-7-23 17:55 编辑 造原子弹够吗?呵呵 X Axis Max Speed: 40 ipm (inches per minute) Resolution: 0.000125in Backlash at 100% load : 0.003in Max Travel: 4.5 in Homing Repeatability: - +/-0.0005 in Repeatability: +/-0.002 in at 0% load Y Axis Max Speed: 40 ipm (inches per minute) Resolution: 0.000125 in Backlash at 100% load : 0.003 in Max Travel: 4.8 in Homing Repeatability: - +/-0.0005 in Repeatability: +/-0.002 in at 0% load Z Axis Max Speed: 40 ipm (inches per minute) Resolution: 0.000125in Backlash at 100% load : 0.003in Max Travel: 3.45 in Homing Repeatability: - +/-0.0005 in Repeatability: +/-0.002 in at 0% load A Axis Max Speed: 20 degrees/second Resolution: 0.025 degrees Backlash at 100% load : 0.05 degrees Max Travel: 100 degrees (90 degrees +/- 5 degrees) Homing Repeatability: - +/-0.05 degrees Repeatability: +/-0.05 degrees at 0% load B Axis Max Speed: 40 degrees/second Resolution: 0.025 degrees Backlash at 100% load : 0.05 degrees Max Travel: continuous rotation Homing Repeatability: - +/-0.05 degrees Repeatability: +/-0.05 degrees at 0% load Spindle Spindle Speed: 65-10,000 rpm Power Output: 104 Watts Spindle Motor: BLDC 3 Phase with Hall Feedback Spindle Runout: 0.000078in Tool Change: Lever Type (no wrenches needed) Tooling: 1/8in or 3mm shank Machine Control BeagleBone Black running Machinekit/ Features Spindle Override Feed Override Stop, Start, Pause Jog while pause 5 axis simultaneous movement Ethernet connection Accepts Standard Gcode Power Source: 90-264 VAC, 127-370 VDC, 47-63Hz Components 7 NEMA 17 Motors 3 linear lead screws with preloaded nuts 4 rotary 8/1 belt drives Linear Bearings, 9 & 42mm, 10% preload Angular contact rotary bearings 6061 Aluminum Frame, +/-0.002in squareness Machine Dimensions: Fully extended: 17.5 in wide(444.5 mm) x 12.5 in (317.5 mm) tall x 11 in (279.4 mm) deep Fully compressed: 13 in wide (330.2 mm) x 9.5 in (214.3 mm) tall x 9 in (228.6 mm) deep Software Autodesk Fusion360, post processor included |
本帖最后由 aaronlen 于 15-7-24 11:07 编辑 然并卵。。。没有铸铁T架,精度一般般,不过不要小看加工哦骚年门,这种微型的,倒是可以做做要求不高的件,比如神主牌什么的,只要进刀量放小点,转速高点还是可以应付的,如果要做精度高的,比如2个C以内,你就不要强求这种做的,能做到20个C精度算不错了,要买,就买有铸铁T架的机,变形应力小,才能保证精度能出来,否则,一切都是浮云。 看这个东西,还得要弄个平台固定,对刀对水平,也不是一般人能应付得了。。。。同时,转速10000转,表面高光也很难做得到啊亲。。。。 另:铝板硬度,铝合金分常用的几种,6063、6061、6005,还有一般所说的航空铝7075 硬度由大到小是7075-6005-6061-6063,其中6005跟6061硬度差不多,做得好的话,韦氏硬度都有13度以上,6063普遍在9-13度的范围内,极少数能到13的,多数是10-12度,7075一般可以去到18度以上,做底盘首选7075,油板6005或6061,道选6061.因为6005非铝成分较高,做氧化不及6061好,不过都是喷小号砂,没相干了。一些固定件什么的,6063是最好的,做出来的表面效果要比6061-6005要好,氧化效果也不容易出现色差。 |
