本帖最后由 Traxxas 于 17-7-7 19:06 编辑 TRAXXAS技术贴视频第八期---如何更换舵机齿 视频原创发布者 BY TRAXXAS 翻译者 BY TRAXXAS中国总代理电波模型 因涉及到模型专业术语,如若翻译有误,欢迎指正!
以英文原档为准,请参考: TRAXXAS – HOW TO REPLACE SERVO GEARS Follow these steps to replace the internal gears in your TRAXXAS servo. If the servo is receiving power but stutters or does not turn the wheels, replacing the internal gears can opt in remedy the problem. We will use a 2075 servo for this demonstration. But the process is similar for smaller and larger servos. Make sure to get the appropriate gears for your servo. TRAXXAS lithium grease is recommended for lubricating the new gears after they have been installed. Remove the four screws to open the servo. Note the placement of each gear, it may help to take a photo to reference when putting in the new gears. Remove the existing gears and bearings, and thoroughly clean all debris and grease from the case. Install the new gears and bearings according to the diagram using the original pins. Be sure the rubber seal goes on the larger gear and that the top of the gear faces the front of the servo. With the new gears installed, apply a few dabs of lithium grease for lubrication. When putting the case back together, ensure that the rubber gasket stays in place. Now reinstall the screws to close the case and your servo is as good as new. 请支持行货电子设备,电波模型总代理承担非人为损件保修一年,直接换新! 如果您想了解更多关于我们品牌的资讯, 请咨询电波模型淘宝店旺旺客服: http://rcmart.taobao.com/?spm=a1z10.1-c.0.0.U0xSpE 微信扫一扫,可得知最新资讯!
或联系我们 QQ :2713236907/270570161 手机:13790546054 王小姐 |
