看了组合图,应该和旧款通用。改了轮圈接合器。 新特点 new high-competition micro racing platform designed by legendary RC designer and XRAY’s award-winning Chief Designer - Ing. Hudy Juraj well suited for high-performance brushed and brushless micro motors 4WD shaft-drive ultra-efficient drivetrain fully independent front and rear suspension 6 cell in-line chassis CNC-machined from premium 1.6mm graphite revolutionary XRAY Multi-Flex Technology™ top deck allows independent front/rear flex adjustment new touring car-style hex hub wheels mounting system with aluminum wheel nuts new harder arms for more aggressive and sharper handling 6° caster arms for improved stability externally-adjustable smooth ball differentials front and rear (factory pre-assembled) ultra-low center of gravity longer 150mm wheelbase for improved stability redesigned premium Swiss 7075 T6 aluminum universal adjustable motor holder drivetrain includes 16 high-speed, high-quality ball-bearings for maximum efficiency and speed ultra-true aluminum center drive shaft reinforced steering blocks and rear uprights to better withstand hard impacts graphite battery strap holds batteries securely in the chassis coil-over shocks for precise chassis handling adjustable shock position for suspension adjustment high-resilience lightweight front foam bumper with graphite bumper brace 2.5° rear toe-in links for higher top speed and sharper handling dual spring-loaded servo saver protects steering servo mounted foam tires: 50deg (shore?) front, 35deg rear for maximum stability and easy handling for optimum gear ratios, both a 36T and 42T spur gear with a selection of pinions included lightweight high-performance sedan racing body with adjustable body posts [ 本帖最后由 fox5y 于 2006-12-2 11:11 AM 编辑 ] |
原帖由 马达王 于 2006-12-2 08:37 AM 发表 同意,觉得这车最大的作用还是在轮子的结合方式上。但要看看轮胎的供应问题能不能尽快跟上来。不过XRAY出的还是比较放心啊。 其实在1/18里HBX早就用了大车的轮圈结合方式,但是没人给他出轮胎 。所以也是白费,哈哈。 但是不改变避震的安装方式我就觉得不好了,可能这车配的是加硬摇臂吧,但是也是不能从根本上解决问题的。 |
