发表于 13-8-15 11:12:24 |显示全部楼层 来自: 中国上海
下面是程序
  Button
Turns on and off a light emitting diode(LED) connected to digital
pin 13, when pressing a pushbutton attached to pin 2.
The circuit:
* LED attached from pin 13 to ground
* pushbutton attached to pin 2 from +5V
* 10K resistor attached to pin 2 from ground
* Note: on most Arduinos there is already an LED on the board
attached to pin 13.
created 2005
by DojoDave <http://www.0j0.org>
modified 30 Aug 2011
by Tom Igoe
This example code is in the public domain.
http://www.arduino.cc/en/Tutorial/Button
// constants won't change. They're used here to
// set pin numbers:
const int buttonPin = 2;     // the number of the pushbutton pin
const int ledPinA =  8;
const int ledPinB =  9;
const int ledPinC =  10;
const int ledPinD =  11;
const int ledPinE =  12;// the number of the LED pin
#include
Servo myservo;  // 定义舵机对象,最多八个
   int pos = 0;    // 定义舵机转动位置
// variables will change:
int buttonState = 0;         // variable for reading the pushbutton status
void setup() {
  // initialize the LED pin as an output:
  pinMode(ledPinA, OUTPUT);
pinMode(ledPinB, OUTPUT);
pinMode(ledPinC, OUTPUT);
pinMode(ledPinD, OUTPUT);
pinMode(ledPinE, OUTPUT);
  // initialize the pushbutton pin as an input:
  pinMode(buttonPin, INPUT);
  myservo.attach(7);  // 设置舵机控制针脚
void loop(){
  // read the state of the pushbutton value:
  buttonState = digitalRead(buttonPin);
  // check if the pushbutton is pressed.
  // if it is, the buttonState is HIGH:
  if (buttonState == HIGH) {
    // turn LED on:
    digitalWrite(ledPinA, HIGH);
    digitalWrite(ledPinB, LOW);
    digitalWrite(ledPinC, LOW);
    digitalWrite(ledPinD, LOW);
    delay(700);
    digitalWrite(ledPinD, HIGH);
    digitalWrite(ledPinE, LOW);
          for(pos = pos; pos>=1; pos-=1)
        myservo.write(pos);
        delay(10);
  else {
    // turn LED off:
    digitalWrite(ledPinA, LOW);
   // 0到180旋转舵机,每次延时15毫秒
      for(pos = pos; pos < 180; pos += 1)
        myservo.write(pos);
        delay(10);
   delay(800);
    digitalWrite(ledPinB, HIGH);
   delay(400);
    digitalWrite(ledPinC, HIGH);
    delay(400);
   delay(400);
delay(500);
   delay(300);
    delay(250);
    delay(100);
    delay(100);
    delay(100);
   delay(300);
    delay(250);
    delay(100);
    delay(100);
    delay(100);
   delay(300);
    delay(250);
    delay(100);
    delay(100);
    delay(100);
    delay(100);
    delay(80);
    delay(600);
    digitalWrite(ledPinE, HIGH);
    delay(300);
    delay(100);
    delay(100);
    delay(100);
    delay(100);
宅宅宅 超级元老 发消息
发表于 13-8-15 11:36:22 |显示全部楼层 来自: 中国福建福州
这是摄像头吗?技术宅啊。
TIGER9901 金牌 Fans 发消息
发表于 13-8-15 19:41:09 |显示全部楼层 来自: 中国北京
帅,程序完全看不懂。
Rseason 终极 Fans 发消息
发表于 13-8-23 19:05:46 |显示全部楼层 来自: 中国广东深圳
技术贴!呵呵!顶起!
唐乾钧 超级元老 发消息
发表于 13-8-29 03:49:07 |显示全部楼层 来自: 加拿大
说句实在话,这个有点小肉啊。。。程序只是设定了两个舵机的转动角度和一些灯光闪烁的时序,只是为了给静态做灯饰的话用arduion就有点杀鸡用牛刀了。
发表于 13-8-29 19:56:57 |显示全部楼层 来自: 中国上海
唐乾钧 发表于 13-8-29 03:49
说句实在话,这个有点小肉啊。。。程序只是设定了两个舵机的转动角度和一些灯光闪烁的时序,只是为了给静态 ...
是的。。。。初学,不会玩啊
唐乾钧  我在上大学的时候和arduino有些接触,在北美这边貌似很流行,除了10位的ADC稍微弱了一点,别的还是很ok的,你用的是什么版本?uno还是nano还是mage?有兴趣可以交流。  发表于 13-8-29 20:06
发表于 13-8-29 20:10:36 |显示全部楼层 来自: 中国上海
谷谷 发表于 13-8-29 19:56
是的。。。。初学,不会玩啊
我用的是uno,刚刚接触这块,还不是很懂,你有作品什么的可以分享一下吗?
kuSAdelang 初级 Fans 发消息
发表于 13-8-30 13:35:08 |显示全部楼层 来自: 中国广东广州
高手啊。。技术宅男啊。
ETHANCHEN 高级 Fans 发消息
发表于 13-9-2 13:13:42 |显示全部楼层 来自: 加拿大
LZ很牛逼啊,怎么做的,灯光怎么穿啊?我之前试过就是电线很难搞进去啊
yjz03658 高级 Fans 发消息
发表于 13-9-11 10:33:22 |显示全部楼层 来自: 中国北京
这个程序没看懂,东西外观和前卫,就是动作没表现好 帮顶
