General Acronyms LHS – Local Hobby Shop CG – Center of Gravity GC – Ground Clearance 2WS – 2 wheel steering 4WS – 4 wheel steering BL - Brushless BND - Bind and Drive ESC – Electronic Speed Controller BEC – Battery Elimination Circuit RX – Receiver TX – Transmitter RTR – Ready to Race or Ready to Run ARTR – Almost Ready to Run MM – Motor Mount (or millimeter depending on context) DIG - Disengages the rear or front drive shaft from the transmission's power and applies brakes so that the front or rear wheels can spin independently. WB – Wheel Base SS – Servo Saver BTA – Behind the Axle MOA - Motor on Axle TT – Torque Twist SCT – Short Course Truck CVD - Constant-Velocity Driveshaft CVA - Constant Velocity Axle DIFF – Differential R/C – Radio Controlled 2WD - Two Wheel Drive 4WD - Four Wheel Drive FOC – Forward only Conversion (refers to modifying a transmission to only work forward) LSN - Low speed needle HSN - High speed needle Brand specific CC – Castle Creations TRX – Traxxas AE – Team Associated HB – Hot Bodies LOS – Team Losi PL - Proline JC - JConcepts TRF - Tamiya Racing Factory Battery specific NiCd – Nickel-Cadmium battery (nickel oxide hydroxide) Lipo – Lithium Polymer battery NiMh - Nickel-Metal Hydride battery 2S, 3S etc. – Refers to the number of cells in a lipo battery Mah – Milliamps per hour Radio specific TQ3 - Traxxas 3 channel radio DX* - Spektrum's series of surface/air radios. (DX2.0, DX3E, DX3R, DX3S, DX7, DX6i, etc.) |
