彭厚超 终极 Fans 发消息
发表于 25-6-12 07:59:47 |显示全部楼层 来自: 美国
NEW from Team Associated, the RC10B84 and RC10B84D Team Kits!
Designed with cutting-edge features, this competition machine delivers superior handling and control. Its molded height-adjustable gearboxes ensure optimized drivetrain efficiency.
Features:
- Molded Height-Adjustable Gearboxes Front and Rear with Additional +2 Rear Gearbox for High-Grip Conditions
- Long-Arm Suspension Geometry: improves grip and predictability in all conditions
- Optimized Steering Bellcranks and Rack: improved bumpsteer control at all ride heights
- Chassis Bracing: Fine-tune chassis flex characteristics with upper and lower chassis bracing front and rear
- Standard and HRC (High Roll Center) Rear Hubs Included
- Insert adjustable caster block with 0, +/-1, and +/-2 degree inserts included
- Forward and Back Motor Positions: used for further weight bias adjustment
- Highly Adjustable Battery Holder with Thumb Tabs: allows for easy battery removal and fine-tuning of weight bias
- 2.5mm Thick Tapered 7075-T6 Aluminum Chassis with 10 Degrees of Kickup and Improved Departure Angle
- Molded Ring and Pinion Gears Included
- Aluminum Center-Mounted Servo Mount
- Two heights Included for Rear Wing Mount
- 7-inch Rear Wing
- Low-Profile Body
- Shock Tower Covers Front and Rear
- 3.5mm Turnbuckles and Ballcups
- 13mm Big-Bore Shocks
And MORE!
Get yours on order here and we'll see you on the podium!
RC10B84 - https://60years.associatedelectrics.com/rc10b84-team-kit/
RC10B84D -
https://60years.associatedelectrics.com/rc10b84d-team-kit/
#WeAreAE #WorldChampions #B84
彭厚超 终极 Fans 发消息
发表于 25-6-12 08:02:45 来自手机 |显示全部楼层 来自: 美国
重点总结:
和b7一样的长摆臂几何
转向组重新设计
可调caster
新的电池固定方式
原厂带避震架防磨
彭厚超 终极 Fans 发消息
发表于 25-6-12 08:05:56 来自手机 |显示全部楼层 来自: 美国
彭厚超 终极 Fans 发消息
发表于 25-6-12 08:07:45 来自手机 |显示全部楼层 来自: 美国
彭厚超 终极 Fans 发消息
发表于 25-6-12 08:09:03 来自手机 |显示全部楼层 来自: 美国
彭厚超 终极 Fans 发消息
发表于 25-6-12 08:09:55 来自手机 |显示全部楼层 来自: 美国
poiuyuiop 元老 Fans 发消息
发表于 25-6-12 11:58:13 |显示全部楼层 来自: 中国北京
猛一看还以为是台8越
彭厚超 终极 Fans 发消息
发表于 25-6-12 12:42:23 |显示全部楼层 来自: 美国
ae这波更新放在世界赛之前,给自己上强度了啊
普莱斯上尉 中级 Fans 发消息
发表于 25-6-12 13:06:38 来自手机 |显示全部楼层 来自: 中国
不知道什么时候出货
洪宇 长老 Fans 发消息
发表于 25-6-12 17:58:30 来自手机 |显示全部楼层 来自: 中国
等一波开箱、落地,对比视频
