XB9 Alu 10° King-pin Steering Blocks - Swiss 7075 T6 Authentic XRAY alu steering blocks with 10° kingpin for XB9 are CNC-machined from premium Swiss 7075 T6 aluminum, hardcoated for extra durability and long life. New kingpin steering blocks with 10° inclination for increased in-corner steering. Recommended for technical tracks where in-corner steering is needed. This new steering blocks are also 1mm narrower which helps increase the steering. Using the standard wheel hexes, offset is -1mm compared to old steering blocks with standard wheel hexes. Ultra-strong construction provides very long life and durability in even the most extreme racing conditions.
Authentic XRAY alu steering blocks with 10° kingpin for XB9 CNC-machined from premium Swiss 7075 T6 aluminum Hardcoated for extra durability and long life 10° kingpin inclination 1mm narrower Increased in-corner steering Using the standard wheel hexes, offset is -1mm compared to old steering blocks with standard wheel hexes Ultra-strong construction for long life and durability #352258 Alu 10° King-pin Steering Block Right - Swiss 7075 T6 #352268 Alu 10° King-Pin Steering Block Left - Swiss 7075 T6 |
