价格只要1099美元 长度: 33.55" (776mm) 宽度: 14.88" (378mm) 高度: 14.55" (370mm) 重量: 25lbs (11.3kg) 离地间隙: 4.25" (107.9mm) 轴距: 19.74" (501mm) 底盘: 冲压钢 Shock Type: Oil-Filled, Coil-Over Springs Drivetrain: 4WD (locked front and rear) 差速器: 直轴 Ball Bearings: Full ball bearings throughout Features • New 1/6 scale chassis design is based on the proven SCX10™III • Includes AR90 standard axles with a Heavy-Duty Spool • Metal gear transmission comes pre-configured for two-speed action (High-speed and Low-end gearing) • Durable three-link front and four-link rear suspension setup provides optimal handling • Replica V8 engine cover adds to the realistic appearance • Detailed Jeep JLU Wrangler body includes functional LED headlights and taillights providing exceptional scale looks and performance • High-traction, 7" tall BFGoodrich KM3 tires, pre-mounted on Black Rhino Primm 3-piece beadlock wheels • AMAZING New Spektrum Electronics featuring: o Spektrum DX3 2.4GHz DSMR radio provides superior range, response, and interference resistance and is compatible with Smart technology. o Spektrum Firma Crawler 120A ESC feeds telemetry data to the DX3 transmitter in real time o Spektrum S905 Large Scale Metal Gear steering servo (also accepts larger 1/5 scale servos with the included adapter) (1) Axial® SCX6™ Jeep® JLU Wrangler 1/6 Scale 4WD RTR (1) Spektrum™ DX3™ Smart Transmitter with Thumb Steer (1) Spektrum™ 5-Channel DSMR® Sport Receiver (1) Spektrum™ 1/6 40kg Waterproof Digital Servo (1) Spektrum™ 15kg Servo for 2-speed Shifting (1) Spektrum™ Firma™ Crawler 120A Sensored Brushless Smart ESC (1) Spektrum™ Firma™ 1200Kv Sensored Brushless Motor (1) Servo Adapter for Large Scale Servos 特征这里捡重点翻译下:有高低速,LED灯,17.78cm直径的百路驰KM3轮胎,4S 120A电调(外观像开山斧),5684 1200Kv有感无刷电机(像好盈贴牌定制的),舵机可以兼容5车舵机,原厂40kg,换挡舵机15kg。 RTR只有3S,对这个1/6来说压力有点大,换城堡1717或者2028套装,8S玩会更好些。 |
