nivea 金牌 Fans 发消息
发表于 08-10-23 15:28:28 |显示全部楼层 来自: 中国广东广州
ヨコモブースではヨコモレディの二人がお出迎え。西山さやかさん(左)と野村瑠里さん(右)。お二人の情報はブログをチェックしてくださいね。
A little period was less crowded from the previous production, but Goodyear racing B324R is finally done release. Parenthesis good quality of the eye which you saw of course is, but the rear overhang is shorter than as much as 34 skylines, it is the atmosphere whose balance of travelling quality is appealing. 11 end of the month sale schedules.
Super PLUS which the option part standard is equipped appears in the drift package. Because the part which it has an influence on running mainly largely is equipped, it is the package which it runs ringing with the circuit and the like densely it is it recommends to the user which is without fail. 12 end of the month sale schedules.
The super luxurious specification which furthermore adds option to Super PLUS. Also estimate value has become the ¥55,000 (classified by tax) with, but it has become the package which has value above that. The response high so with the chassis of the carbon mixture resin and the aluminum part around the steering wheel image. Because it becomes the limited production item, we ask the purchase ahead of time. 12 end of the month sale schedules.
Light unit of sample only is equipped in ER34 of ICHIROKU M. In any case [katsukoii]! Don’t you think? it just decorates it is appealing.
Also the option of ICHIROKU M considerably boiled down. Still, sale time and price etc it is undecided, but as for the upper/lower suspension arm and the aluminum part of the bulkhead and the like were displayed.
The option part of CL Challenger1.9 many appearance. We displayed also the aluminum part and the large diameter tire etc, but large portion is thought that it can ship promptly.
When the long wheel base and the wide axle and the large diameter tire are equipped, rather it is finished in the image which has force. When using the large diameter tire, because also the burden for servo is large, if it is possible, it was to use servo it has torque is, it came to be, with the shank.
Because it does not finish to be settled in the exhibition space, [toragishiyashi] RC8T of [asoshieitetsudo] which is hung in the wall. Already having been sold and being started
YZ-114SPC of special specification joins to YZ-114SP which becomes the popular item of the extent where production does not overtake. Seeing, sort in the carbon print case and black panel specification, it finishes in the feeling which is astringent and the [tsu] [te] is. Because it becomes the limited production item, please ask ahead of time. Middle of November sale schedule.
The PRO tire warmer which even the necessary item of the race/lace user can be said evolving, re-appearance. Optimum temperature management being automatic with programming function of temperature control and 4 steps of 4 wheel independence, it can do, just it is the masterpiece of the tire warmer. Also power source corresponds to 7.2V~12V. So earlier November sale schedule.
Management of the troublesome rose cell battery is borne, the single cell ionizer and the YZ-CMS cell management system of the liquid crystal indication attachment. Verification of discharge state is possible of course compilation of the simple matched battery.
The motor power station which is convenient to the check and the simple training of the motor. From 100V power source connecting to the motor, selects output voltage just the simple operation of saying is charm from 2V/3V/4V. Price undecided.
The battery checker which can do the voltage check of the 1~6 cell and the Li-po3 cell battery of the nickel hydrogen nicad sample only. Connector form and the like may be modification still, is, but because the estimate value ¥1,500 (classified by tax) with it is set to [rizunaburu], easily is. Because the Li-po battery can indicate also the voltage every of cell, also balance check is possible.
In the event space inside the meeting place it did also the demonstration of drift radi-con. It is exhibition schedule even in [neohuesuta] which is done in November, but because from this becomes the event of attendance person participation type, you think that method of enjoying which in addition is different is possible. Of course with [yokomo] it is the schedule which does experience travelling of the drift. Please attend by all means.
632004376 论坛元老 发消息
发表于 08-10-24 12:12:26 |显示全部楼层 来自: 中国浙江绍兴
漂亮 漂亮 漂亮
我是说女的  但车也不赖
