Garphy 论坛元老 发消息
发表于 19-5-10 10:49:35 |显示全部楼层 来自: 中国福建
Tamiya-57409-Lunch-Box-Mini-SW-01-Chassis-1.jpg Tamiya-57409-Lunch-Box-Mini-SW-01-Chassis-b-1.jpg Tamiya-57409-Lunch-Box-Mini-SW-01-Chassis-c-1.jpg
Tamiya-57409-Lunch-Box-Mini-SW-01-Chassis-5.jpg Tamiya-57409-Lunch-Box-Mini-SW-01-Chassis-2.jpg
1:24,20cm不到,4WD,类MINIZ前轮避震;
转弯带倾斜车身,可升级四轮转向,转弯半径极小;
PC车壳预上色,磁铁固定;
标准舵机,自带370电机,齿比21.875:1;
最大电池规格:66x36x15mm
支持4颗5号电池,需另购电池盒(编号:51610)
官方定价折算600RMB!买爆!
视频第一个特写
https://v.youku.com/v_show/id_XN ... j.8428770.3416059.1
第二个行走姿态
详细规格懒得翻。
SWD-01 chassis key features:
•        The steering uses 1-piece upper arms for a tight turning circle and the body leans to help suppress tumbles. It can be converted into a 4-wheel steering setup with separately sold Item 54898 SW-01 Upper Arm Connectors.
•        The body is attached to the body mounts using magnets for quick attachment.
•        The Type 370 motor is located right in the center of the SW-01 chassis, in a gear-driven 4WD setup with a gear ratio of 21.875:1.
•        1/24 scale R/C model assembly kit. Length: 190mm, width: 146mm, height: 140mm.
•        The famous Lunch Box body is molded in lightweight and durable polycarbonate and is pre-painted.
•        The body leans in the direction in which the model steers, achieving remarkably tight turning circles.
•        Responsive 4WD.
•        Strut style suspension.
•        Can be used with standard size servos and R/C equipment despite its compact nature.
•        Big, tread patterned tires give superb traction and add to the overall cartoonish look of the Lunchbox Mini.
•        Dish type wheels.
•        Compatible with Tamiya LF Battery LF1100-6.6V Racing Pack (M-Size) as a power source.
•        Aftermarket battery note: Battery pack size must be under 66x36x15mm in size.
•        370-type size motor included.
•        Requires: 2-Channel Radio, standard size servo, 7.2-7.4volt battery pack & compatible charger.
•        Compatible with: item 51610 RC T301 Battery Case for use with 4 AA batteries if desired.
silversol 论坛元老 发消息
发表于 19-5-10 10:51:49 |显示全部楼层 来自: 中国上海
估计是小三轮类似的倾斜转向方式
tutuge 论坛元老 发消息
发表于 19-5-10 11:01:41 |显示全部楼层 来自: 中国浙江杭州
这个价格太赞了
MLYLL 终极 Fans 发消息
发表于 19-5-10 11:05:24 |显示全部楼层 来自: 中国陕西宝鸡
这个必须买。
飞翔燕尾服 元老 Fans 发消息
发表于 19-5-10 11:18:39 |显示全部楼层 来自: 中国山东
什么时候上市?
Garphy  7月 .  详情 回复 发表于 19-5-10 11:31
Garphy 论坛元老 发消息
发表于 19-5-10 11:31:25 |显示全部楼层 来自: 中国福建
飞翔燕尾服 发表于 19-5-10 11:18
什么时候上市?
7月   .
zaku 超级元老 发消息
发表于 19-5-10 11:49:28 |显示全部楼层 来自: 中国江苏
视频最后那三轮车翻不回来了,哈哈。
小饭盒两个问题,1是轮子不好看,2是已上色的车壳没个性。
Garphy  应该都能换  发表于 19-5-10 12:51
dbqkiss RC 新手 发消息
发表于 19-5-10 11:56:17 |显示全部楼层 来自: 中国内蒙古呼和浩特
萌萌哒.....
michaelboy 元老 Fans 发消息
发表于 19-5-10 15:57:07 |显示全部楼层 来自: 中国陕西西安
要是把田宫的四驱车改成遥控蚊车,肯定大卖
jog 超级元老 发消息
发表于 19-5-10 16:07:11 |显示全部楼层 来自: 中国北京
没看出来倾斜车身啊
Garphy  一点点还是有的··  发表于 19-5-10 21:27
