Reds 推出全新21级 5ports越野车(Buggy)引擎,由遥控车引擎大师Mario Rossi先生亲自调教和装配。这是一款长冲程引擎,14mm平衡处理过的曲轴,高强度活塞链接杆,瑞士轴承。从参数方面看,这是一台高性能引擎,期待早日来到中国让玩家体验其真正实力!
Boosters effect Thanks to the ABC cylinder configuration, 5 inlet ports and exhaust port with boosters, the engine provides maximum power at each rpm and ensures low fuel consumption. Lightweight The new REDS R5T is extremely light! With 348 grams of weight is one of the lightest engines in its class. The engine has been completely redesigned to save even further weight, maintaining high performance and reliability. Perfect balance Our latest generation crankshaft is balanced with high density weights. Silicone filling reduces the inertia to rotation. Through the use of special steel and heat treatment, the component is particularly strong and surprisingly reliable. High performance ball bearings The engine comes with all Swiss Made ball bearings. The new high quality Cr steel rear bearing ensure longer life and extreme performances. New composite carburetor The new composite technology provides extreme carburetion stability. Interchangeable venturi and single adjustment minimum needle, facilitating the engine carburetion to achieve high performance. New cooling system The new engine is designed for maximum performance in terms of cooling, with a new ultra-finned crankcase and new cooled combustion chamber. Flat Piston All our off-road engines use flat pistons matched to a specific combustion chamber for high performance and low consumption. Made from a high strength aluminium bar, our piston is a true masterpiece of engineering. Ultra-light rod Lightweight, durable and reliable, this is the standard quality of our connecting rod. The slim shape is designed to minimize aerodynamic friction. The double bush technology ensures high reliability. |
